1 - 9 of 9 Posts
i just bought 2007 sequoia, its A/C was not working properly, i recharged A/C gas its working fine now, but i noticed that there is some leakage on receiver/dryer glass. there are little bubbles coming out from side if glass. it seems like oil. how can i stop this leakage, Thanks.
please see the following images
https://postimg.org/image/50boksv0r/
https://postimg.org/image/xr8iav0uj/
· Super Moderator
2005 Corolla CE
If you see bubbles coming out of the glass, you need to replace that leaky part. To do that, you would need to evacuate (remove all refrigerant) the system using a vacuum pump. You would then replace the part and recharge it.
This assumes you have no other leaks and the leak isn't cause by an overcharged system.
There might be multiple leaks. You can't repair it properly without the right equipment, call around for a reasonable diagnostic quote.
They evacuate the refrigerant, fill it with refrigerant+dye, then look for leaks with a blacklight.
Mine had a leak at 2 seals. Diagnostic, repair, and new fill were $385. Diagnostic alone was $120 I think.
· Super Moderator
2005 Corolla CE
its Limited.
It appears the glass is on the line. If it needs the line, the part number is 88716-0C240. It costs around $35 online and will be the lowest price from our forum vendor Roman at Toyota of Cool Springs.
1 - 9 of 9 Posts
