2010 Camry base, 6 speed manual. My front brake calipers were getting noisy, so I took my car into the dealer to clean and lube the calipers. Also, I had them drain and fill the transmission oil.
Well, the first thing I noticed is the tranny took a little more effort to move the shifter after I left the dealer. Seemed to be OK after a while.
I get home, and went back into the garage a while later and noticed a good amount of oil all over the garage floor. Took a look underneath, and the entire driver's side (tranny side) of the car was covered in oil.
Dropped it off at another Toyota dealer that is close to my house. I called the dealer that did the "work" and told them that they totally screwed up and they need to take care of it with the other dealer.
Dealer that I took the car to calls me and tells me that they estimate that the transmission was overfilled by about 3 quarts! It was coming out the top of the vent holes in the transmission!
The problem dealer agreed with me that they will pay the other to do another drain and fill to the proper level, and clean it up the best they could.
With all that said, what, if anything, could have been screwed up by having a manual tranny that over-filled for 60 miles? What else could be affected by having transmission oil all over it? They did a decent job cleaning it up, but still has some oil coating on some parts around CVs, tie rods, etc.:headbang:
By the way, they screwed up my tire pressures too, and put the specs on their inspection sheet as "32", including the temporary spare, when the door jamb says 34 and 60 for temp spare.
