2000 Camry LE 4-cylinder
Seriously need some help here. Every time after I start up my car and press the brake pedal the fuse blows. The fuse is a 15 amp fuse and I bumped it up to a 20 amp and it still blows. The shift lock is set and I can't shift into park without pressing the override switch. I also have replaced the brake light switch. The cruise control is also acting funny, when I tap the brake pedal to knock off the cruise it speeds up and I have to manually turn off the cruise. Apparently some of the cruise control function is in the brake light switch. Please help!
