Hi
my rear passenger side shock absorber is making noise.
Do i have to change both rear shock absorber?
thanks in advance
What I like to do is grab the rear of the car and lift it up and set it down a couple times to see if I hear any noises.No fluid leak.i think these shock absorber is filled with gas not oil.
i will check strut mount tomorrow.
The whole bump stop needs to be replaced then. It's supposed to be one piece with 5 little sections... all connected together.as you can see spring bumper is divide into 5 part,only one part of that came out.
Ali - Gas filled shocks/struts still have oil in them.No fluid leak.i think these shock absorber is filled with gas not oil.
It is strongly recommended.one more question,i want to remove shock absorber from the car and check where the problem is,then connect it again in order to buy proper part for it.Do i have to align the wheels after this job?
you were right,the problem was suspension support.i tried to remove the shock absorber from the car today but failed:headbang:.That Suspension support (Strut Mount) Is what makes noise 90% of the time.
the two bolt at the bottom of shock absorber....i could not loosen them(19 mm).i used wd_40,no result.:facepalm:
