1 - 4 of 4 Posts
I have determined the keyless entry system in my 2014 corolla is causing a short making certain dash signals to flash while driving. When I removed the lower instrument panel, I discovered a hanging black wire. Does anyone know what the wire around the yellow marking could be? I was thinking about just grounding it and see what happens. Or could it be an antenna for the keyless entry system? Thanks!
283400
2016 Toyota Corolla
No one will know unless you trace it back to where it comes from. Could be the ground but why not trace it back???
Super Moderator
2006 Corolla XRS
You will need to trace the wire to it's source to know for sure if it's for ground, power, or signal.
2016 Toyota Corolla
OK, so I went through the service manual and most likely that is the ground...
So you need to ground that to the left of the kick panel. I will send you something so expect a PM.
1 - 4 of 4 Posts
