221 - 240 of 319 Posts
Discussion Starter #224 (Edited)
Can anyone confirm this? I have a 2013 Camry SE V6 in Super White.. They look the same to me.
The 2014 corolla s does use the same turn signal.
COVERS -:
Left side -: 87945-02420-(A0) Super White.
Right Side -: 87915-02420-(A0) Super White
TURN SIGNALS -:
Left side -: 81740-52050
Right Side -: 81730-52100
Any chance this will work on a gen 6 camry?? Anyone know for sure??
COVERS -:
Right Side -: 97915-02420-(A0) Super White
TURN SIGNALS -:
Onequan, for the right side cover in super white, should the part number be 87915-02420-(A0) ?
help !
one part that has me a little lost is i see you give the pin for each signal but where did you ground it to ?? just want to make sure ?
No space for it. You can cut a hole in there if you want. I researched this a while back trying into figure out a way to get a puddle light in there. You will have to buy the whole Venza housing, just the black plastic that the light and mirror sit in, which was about 189 per side. Then there is no guarantee that the mirror arm on the Camry will fit the Venza housing.
"Circle of trust"
Oh I think I found the connector that plugs into the turn signal. It is a "K" connector i11, just need to find a part number. Would someone that works at the dealership find a part number for this connector?
