1 - 20 of 21 Posts
Nostalgia Member
does anyone seem to have this problem on their gen 3, or is it just me?
this happens even when the tires are filled to the recommended psi, and just fyi: it was about 60*F when i took the picture, so there shouldnt be a big psi drop
R.I.P. '95 Camry LE V6
'95 Toyota Camry LE
with my old tires yes.
93 Camry LE
Ive never had tires NOT do that....??
'95 Camry 5S-FE
95 Camry LE
That is another reason why you need after market wheels with low pros.
mine do that, no idea why but it does.
Nostalgia Member
Discussion Starter #6
none of my buddies do that, but they all have low profiles - so i guess thats why?
wasnt sure
'95 Toyota Camry LE
yeah the thinner the side wall the less "flex" it has. when i was looking for tires, i was told that i could go with 215/60/15 for the flatter/smooth side wall.
Old fogey
Sidewall flex is for little boys. Real men keep it stiff.
Low profile FTW.
Nostalgia Member
Discussion Starter #11
wow thats REAL bad, id say your car will only last a few weeks with that!! only way to fix it id some nice 17" black whees with low profile tires ;).
send me some IS300 wheels, ill pay for shipping :D
Nostalgia Member
Discussion Starter #14
i guess im just used to the Subaru because the Camry hasnt been driven much since Winter Break (by me or anyone)
93 240sx SR Hatch
1999 Solara
camber+ sidewall flex+14s=death
Low profile tires, especially summer only tires, have a much stiffer sidewall carcass, which is why they dont flex.
Initiated as an Outlaw...
yeah mine do that too, but only when its hot!
Radio, this is Unit 91...
1993 Camry LE AT
I typically run my tires at ~5 psi above "recommended" pressures.
Some tires have more flex than others.......those pics are too serious though. Nothing to worry about.
03 Toyota Highlander
My stockies did that. Its normal, the sidewall is huge. My IS rims didn't.
You want IS rims, if you pay for them lol. mine are still sitting the garage.
Nostalgia Member
Discussion Starter #19
did u need spacers? (i think only the 4cyl guys need them, but im not sure) ... and how much?
shipping would probably be half a million dollars tho
I needed spacers at the rear to clear the struts.
4cyl need it at the front to clear the calipers. Dunno if you need it in the rear though.
Yeah shipping sucks cock.
1 - 20 of 21 Posts
