1 - 11 of 11 Posts
G
I have a 91 extened cab pickup. My turn signals stopped working. The
hazzard flashers work and the lights blink, as well as the brake light
and parking lights.
When I push down or up....nothing. All lights are on and it doesn't
appear to be a burnt out bulb.
Any suggestions? The Haynes mannual doesn't really offer anything.
Thanks for your help.
John
G
Discussion Starter · #2 ·
<[email protected]> wrote in message
news:[email protected]
> and parking lights.
> John
You said that all the lights are on. Do you mean the turn signal bulbs
light up but don't blink? If so it sounds like you may have a bad flasher.
G
Discussion Starter · #3 ·
no...they don't come at all when I use the turn signal....nothing. I
thought it was bad bulbs but they work when I use the Hazzard switch.
Suggestions?
G
Discussion Starter · #4 ·
"John" <[email protected]> wrote in message
> Suggestions?
Have you checked for a blown fuse or a bad turn signal flasher yet ?
G
Discussion Starter · #5 ·
Nothing happens when I use the turn signal...nothing, no light. The
lights do work when using the hazzard switch.
Suggestions.
G
Discussion Starter · #6 ·
When you use the turn signal lever, do the lights not flash or not come
on at all? If they don't flash, change your flasher module which is in
the fuse block under the dash. If they don't come on at all, your
"combination switch" inside your steering wheel is bad.
G
Discussion Starter · #7 ·
Thanks to all for their replies....Last night I was starting to work on
on all the the small things before tackling the combination switch. I
started with the fuse panel...and I found a blown fuse. I replaced it
with a 10 Amp fuse and the signal lights worked.
Looks like I'll be returning the flasher and 8 bulbs. Thanks again for
your help.
John
G
Discussion Starter · #8 ·
>your help.
Keep the bulbs, and put them where you can find them - with a 15
year old car you'll need them. And when one goes, change them all as
a batch because they all have the same hours on them.
I have a medium size tackle box in the garage with only auto bulbs -
it's cheaper to buy a 10-lamp carton than four lamps in the retail
blister packs. They don't go bad, and they get used.'
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
G
Discussion Starter · #9 ·
The Emergency Flashers and the Turn Signals are the same bulbs and wires. If
the flashers work but the turn signals don't, the trouble has to be related
to the turn signal switch.
> and parking lights.
> John
G
Discussion Starter · #10 ·
"Mike" <[email protected]> wrote in message
>> and parking lights.
>> John
Good call. Assuming the flasher unit is okay, the next thing is the turn
signal switch.
G
Discussion Starter · #11 ·
John try rapidly operating the hazard switch as the hazard switch
disconnects the flashers to operate there might be some sticky mechanism or
dirty contacts rapid repeated operation sometimes frees and cleans the
mechanism for a while.
Joe
> and parking lights.
> John
1 - 11 of 11 Posts
