No sub in my tacoma, but I have a 10" in my corolla. MTX 800W amp. I think I have 0gauge home depot wire for the ground. It goes to the bolt where my middle seat belt used to be on the rear deck. No noise problems for me.
I'm wondering if you have the +12v line running next to the RCA cables for the amp? That could/would cause noise. Usually recommend running them down opposite sides of the vehicle. I ran the one for the car under the body up above everything else as it was easier than pulling up carpet or plastic panels.
Is the ground connected solidly on the amp and truck? Loose ground might cause some noise. Not sure though, it may just cause the amp to cut in and out. I suppose if it did that fast enough for a milisecond or so it could sound like noise.
