1 - 20 of 37 Posts
· back again? yeah, i am.
1992 Toyota Camry
i know its in the camry faqs but i need more than that...bluemeanie u can help with with this one...the step of removing the plastic...do u have any pics?...i never changed bulbs before and really dont know what im doing....i got the 9005 st/2 bulbs and i got the 92 cam...my real question is...does anyone have any pics of the removal of the plastic and what the finished product should look like?and how should i adjust the light?...thanks...reason i need ur guys help is cus i dont want my dad helping me with this install cus he will say no right away before of the modification of the socket
· The Greatest
You have to take ur headlight off.
The light should go in thru a socket or hole and then you are left with a stocklightbulb connected to a wire. You then somehow change it. Im not going to say anything more cause i really dun kno about 92's but im pretty sure that what i said up top is correct.
· Grenaded piston
CamNub said:
Yah, but wouldn't taking it off make it much easier to get the wiring harness out?
Yes, but why go through the trouble of removing the headlight just to change a bulb.
Do you remove the engine from the car to change the oil? :rolleyes:
Not to flame you or anything, but i've noticed that alot of your posts make no sense at all.
1992 Toyota Camry
Discussion Starter · #13 ·
k...im gonna do it this weekend...one more question though...if i modify the socket like the pictures above....can i ever go back to using the 9006 bulbs?
haha, your dad would kill you if you even asked him to help. the car came with the stock parts for a reason!!!! dont ever touch anything, you blow the car up, you know.
1992 Toyota Camry
Discussion Starter · #17 ·
one more question....do i HAVE to put on two o-rings?...or can it be one on the midfied 9005 as bluemeanies description says?
· Zzzz
Camry
88 LE said:
^ No you don't have to put on 2 o-rings.
They'll work fine with just 1 o-ring. The bulbs come with 1 o-ring anyways.
88LE is right, not that my word's stronger than his or anything, but I've been driving with 1 O ring for over a month now and it's been holding tight. Every time I open the hood to check, but I've never had to tighten anything.
1 - 20 of 37 Posts
