I am planning on installing a Sirius Sportster 4 and have a few questions.
1. Is the A-Pillar easy to remove? I see the handles are installed, are they a hassle?
2. Satellite Antennae cable routing and placement: Has anyone found an easy way to run the antennae? I would like to install it in the center above the rear window on the outside of the cab. My radio will be located directly to the right of the drivers A-Pillar.
3. For power can I simply snake the power cord down under the dash after removing the A-Pillar? I will use an "add a circuit" to supply power.
After finding out its gonna cost me $100.00 just for an auxilliary input I am going with the wired antennae modulater instead at 20 bucks. All I want is no static and since 90 percent of the time I listen to Howard Stern the sound quality is not a big issue. Appreciate any help and BTW: I did review other install tips on the DIY thread but they only showed me certain aspects of an install.
