1 - 7 of 7 Posts
Hi,
At a traffic light, my 92 Camry 2.2l idles a little rough. If I shift to neutral, it idles smooth. Is that a motor mount issue? It is really not that bad of an idle and sometimes it does idle smooth in gear. Any suggestions as to where to look to cure this?
TN Pussy Man
Camry
yes, yes it is....
do a search on home-made polyurethane motor mounts....
'96 Camry XLE
TonyD, I have a '92 LE I4 and it is the same thing for me. Been that way for years, I don't even notice it most of the time.
hmmmm....from my experience, it sounds like it could be a few things;
-mount(s)
-ignition related (plug, wire, coil)
-TPS (throttle position sensor)
-fuel related (clogged inj. or fuel filter)
-dirty/restricted air filter
I would check basics first: fuel, air, spark
but if what u describe is just a vibration and not an actual rough idle, obviously its just a mount
Discussion Starter #6
thanks all,
I will start with the mounts. How many motor mounts are there? Are they a pain to get at. Is it involved for a novice? I changed the plugs, wires, dist cap, rotor, pcv valve and coil but I put Bosch plugs and wires in. Maybe that was a mistake.
1 - 7 of 7 Posts
