1 - 20 of 23 Posts
This hose has been broken off for a very long time but I recently was given the car and I want to put it in the best shape possible.
The hose is one of two that is coming off of this particular part:
This is the view that includes the air filter with the broken hose being all the way at the bottom.
I'm guessing this has something to do with a very old post on this forum but the referenced solution is no longer active, the page leads to a 404 error here: Broke one of the vacuum hose connections on the air...
· Super Moderator
1995 T100 2WD & 1993 MR2
This one?
Worked fine for me?
Discussion Starter · #3 ·
This one?
Worked fine for me?
All of the images from the OP are deleted, as well as this link that was the solution: http://robofitinc.thomasnet.com/category/barb-fittings?
is broken my guy.
Discussion Starter · #5 ·
That helps, I was more trying to find the guide that was posted on that website of how to drill it, and exactly which parts would fit. All information that was lost there.
Moreover I'm really interested to find out what this disconnected hose has impacted? It's been off for years at this point and what does not having it connected do to my car?
Many thanks!
Discussion Starter · #7 ·
From what I've gathered so far from reading through countless threads for hours: I believe the part you linked is what has the broken connection, yes.
It seems that the VSV is supposed to have two connections to complete the vacuum in the hoses seen here in this diagram, the broken connection is to the Air Control Valve.
I'm trying to figure out why I've been able to drive with the broken connection to the Air Control Valve for years and if that's making me have less horsepower or just wasting gas? I also was confused because I thought the part that has the nipple on it is the Actuator because of the diagram as well. I didn't know the actuator was simply a part of the Air Control Valve.
· Super Moderator
Sorry my p/n was for a 2005 but close. I agree, confusing.
Local salvage yards probably have what ya need, doubt thats a high demand part even though new isn't terribly expensive.
Check car-part.com for a yard near you. :)
Discussion Starter · #9 ·
Yeah since it's literally just the rubber vacuum hose I'm going to try and just tie something around it so it doesn't slip off the nipple. Do you have any idea what having it disconnected has been doing? Poor performance perhaps?
· Super Moderator
I've been trying to figure that out. Not really familiar with that VSV but assuming the canister the hose connects to has a diaphragm in it that may operate the valve with pressure changes like an accordion. Perhaps emissions related, haven't looked up that particular VSV. Probably more efficiency than power related. Should be interesting once you get it secure and drive it a bit. If it throws a code go back and dis-connect it. lol
2004 Solara SLE Convertible, 3.3 V6
Quite possibly nothing or very nearly nothing. This could be particularly true if compensatory adjustments (whatever those might be) were made years ago.
As @sdspeed implied, it will not come as a shock to many of us if, after the repair is done, a code ends up being thrown.
Reactions: sdspeed
· Official PITA
'05 Solara Convertible & '07 ES350
First...you might be able to use an uncompressed rivet, or two, stacked, as the hose barb.
Iirc, those vac hoses control whether car pulls air from near road surface beneath the car, or from the top. Vaguely remember it had something to do with rain??
Discussion Starter · #13 ·
Would it throw a code because something is wrong with it connected or because maybe the sensor will be tripped again after years of it being "ignored" lol
Discussion Starter · #14 ·
I was VERY much hoping that this would result in some dramatic jump in my MPG because potentially the engine was getting so much air even when it didn't need it (at idle) and then this will fix that. Sure would be a great surprise but I'm not getting my hopes up yet. Appreciate commenting!
2004Toyota Camry V6
That is a vacuum actuator which opens to provide more air when power demands increase. It is just a second supply of air for the throttle body. The solenoid actuator opens/closes the lower air inlet duct. At higher engine RPMs, the engine will be starved for air to match the increase in fuel from the injectors. I haven't checked a price for that component, but you can be sure TMC thinks it's $$$. Regards
Discussion Starter · #17 ·
Interesting, so with it currently being disconnected, the engine has as much air as it needs to perform at high RPMs? Or because it's disconnected it's getting bottle-necked and wasting gas?
Also what is TMC?
Thanks!
· Super Moderator
Is there enough of that nipple left to glue the tubing on? If things improve then go grab the assembly from a salvage yard.
Also, it must have been connected at least visually for emissions testing over the years.
Discussion Starter · #20 ·
Well, it's an extremely small nipple. It's been attempted to be glued on in the past and you can see the clearance is super close.
Table Fluid Material property Gas Circle
Kitchen appliance Fluid Cookware and bakeware Gas Kitchen utensil
1 - 20 of 23 Posts
