1 - 4 of 4 Posts
HI ALL,
I have bad smoke coming out of my exhaust, when i start the car its fine but after i give it a rev it starts smoking hard... and doesnt stop smells like burning oil.
any ideas on what could be wrong it also lacks power...
'96 Camry LE
What color is the smoke?? if its thick white smoke you might have shot valve cover gaskets or the beginning of a BHG (blown head gasket) if you know how check the valve covers and leaks around where the seal is if you have a leak its shot valve covers and you can diy for about 30 usd from your local parts dealer keep us informed on what you find out
Owner of much Obsolete
1986 Corolla GT-S
Turbo oil seals and valve seals are the most common causes for smoking on the JZ engines.
Jeff
1 - 4 of 4 Posts
