Did a test fit of my SSC super-Z LT ZT 735 cable chains for the Highlander P245/55R19 Bridgestone Dueler H/L 400's that are on my Limited.
They fit fine.
There is one hook in the back and two hooks in the front that are part of the installation. Practice probably will make perfect but it took some pull here and pull there to get the slack required to hook the top front. The bottom front had extra slack.
I also indexed the chains so the back clip was at 1200. In this position you are playing around the coil over spring area. The next time I will try indexing it at 1100 to stay clear of the coil over springs.
Soooo...if you have to have a set of cable chains these were the only ones I found that would fit the P245/55R19 tires on my HL.
ON EDIT: Duh should have read the instructions again.. I made the installation harder than it needs to be. I drove onto the chains after I layed them in front of the tire. The chains are made to be installed WITHOUT driving on them. Doing it the right way solves the problem I had with the amount of cable available for the front top connection...Jeez...
Move the chain in a sweeping motion under the vehicle so the open
mid-section is positioned against the backside of the tire.
This sweeping motion can best be done while kneeling in front of the tire.
