1 - 20 of 53 Posts
I did the heated mirror mod this weekend using the Burco RediHeat heating elements. Each cost $25, $50 total. I used a defrost switch from a late 90's 4runner. This switch is an on/off switch, I plan to do a future mod and take out the spring to make it a momentary switch. This will then trigger a 555 timer circuit to turn off after 10 minutes. I tried to make a 555 circuit and couldn't get it right so thats for another day. I found a few kits online which I may pick up.
There doesn't seem to be a left and right element. I used burco #3804 element which works great for the drivers side. The problem is that the passenger side didn't fit so it needed to be cut (which says in the instructions is ok to do), after I cut it I got no heat... So I am going back to likely get a smaller element #3801 for the passenger side. http://www.burcoinc.com/Related_Products/redi_heat.htm
Step 1
I will assume you can find out how to take off the mirror and door panel...
Take the mirror out of the mirror assembly by carefully prying on the bottom side of the mirror. Then dissemble the mirror assembly as shown below.
Instructions do not say what gauge wire to use.... I used 18 gauge wire. Cut two wires about the length from the mirror to the middle of door. Tape them together the entire length and snake them through the mirror assembly as shown. Put the assembly back together, attach the crimp connections (supplied). Make sure to pull all the slack from the existing mirror harness or it will not reach the connection when you put it back. Tape the wires where they exit the mirror assembly.
STEP 2
The mirror is attached to a black plastic backing. I heated an oven to 300 degrees and put the mirror in the oven for 1-2 minutes. This made the plastic flexible so the mirror popped out easy. Peal the paper/foam off the mirror and clean off the glue with whatever cleaner you have (I used acetone). Try to save the foam part to reinstall. DO NOT SCRAPE THE MIRROR WITH A TOOL it will show through the mirror!
Once you have cleaned off the mirror stick the Redi Heat pad on, my foam pad still had sticky on it so I stuck it to the redi heat pad as shown below
You will have to cut the plastic backing so the connections will fit through, I used a Dremel tool. Put the plastic backing in the oven to soften it and pop the mirror back in.
Hook up the connections, (be very careful they can rip easy!) and reinstall the mirror into the mirror assembly. Its a good idea to test the element before you put everything back together.
STEP 3
Reinstall the mirror, snake the wires through the door. Ground one of the wires, I used the window track bolt and make sure to scuff the paint. Disconnect the door side of the rubber boot between the door and the cab. Fish a wire from the cab through the boot and into the door (the yellow wire behind the plastic in the pic below). I used a quick disconnect crimp connection incase I had to remove the mirror in the future, which is tucked behind the stock mirror harness in the pic below.
Do the same for the other mirror and run the wire behind the dash. I did not have to remove any panels except for the door panels. I used a circuit extender from the fuse block to power the switch (use a key switched circuit). I had to dremel the dash a little to fit the switch in. Wire up the switch and you are in business. Photos below are on and off. Like I said I want to add a timer so future mod to come.
STEP 4
Have a beer (for those of age anyway) Easy mod would do it again. Now have to wait til winter for the real test!
2007 Toyota Tacoma
Nice post! I definately wan to do that sometime!!
The pictures originally came up as *red x's* until I actually copied and pasted one of the addresses out of the properties box and pasted it into another window. Then they all showed up. I dunno if that was 'my end' or something else....
Thanks for the writeup!
Red Headed Slut
That did the trick Janster! No more red Xs for me either!
Nice write up! I'm gonna have to do this soon! So you only bought the rediheats and a switch then? I know some others have talked about needing the heating assembly from some heated signal mirrors (since our trucks don't come with that heater element).
i need pics! lol i'm doing this mod tuesday ... i was going to use the 3804's but i placed them overtop of my mirror and yes i'd have to cut them alot.. so i just decided to go with the 3801's since the heat will radiate anyway.
I've got the 555 timer kit coming in as well.. should be here tomorrow!
lover of teh boobies
'05 Tacoma AccessCab
Pics work once you open them in a new window. right click the Red X and choose open in new window. Do this to all of them and then refresh this page.
Or just use Firefox I guess.... They load each time no problem for me... Then again, with FF I never get those annoying red x's.... :lol:
Edit: IE opens them fine too... Maybe your internet's broke? :lol:
Discussion Starter #12
The links are good... I had the same problem using IE on other threads, i think its an IE issue.
The 3804 fits fine for the drivers side. The passenger side is the problem. The rediheat is the heating element. Thats all you need plus a switch. I will probably forget I have them on so I want a timer on them. I have read some other forums and I some OEM cars do not have timers on them, so i don't think its a big issue to leave them on. My s-10 had a timer.
Heres a pic of what I cut and killed it...
Discussion Starter #14
There are lines running around the entire perimeter of the element. You have to cut across them. There is no other way. I emailed the company hopefully I will get a reply. I will grab some more pics of the switch tomorrow.
Discussion Starter #16
I contacted the Redi Heat company and apparently their instructions are incorrent and the #3804 cannot be cut down.... So make sure you use the smaller #3801 for the passenger side mirror.
^ so if their instructions are incorrect are they sending you the replacement for free? :D
Go Sharks!!!
06 tacoma prerunner
I'd like to hook up a relay so whenever i turn on my normal defrosters these will turn on, I guess I gotta start breaking out the multimeter to figure out which wire it is. But these look like they'll work great, i don't need signal mirrors like on the muth but would like some heated mirrors.
1 - 20 of 53 Posts
