This is kinda goofy, but I was itching to build something this evening. Plus I like messing with solar panels. They produce free electricity. Cooooool.
I got this idea from here. http://www.break.com/index/how-to-build-a-solar-powered-usb-charger.html
I got two solar panels from some old garden lights, and wired them together in series. Together they can put out about 14 volts.
I used laminate sheets to seal it all together, like the stuff you use to laminate membership cards and stuff like that. You can't stick ridgid solar panels through a laminating machine, so I got some bubbles when I heated up the laminate with a heat gun. The bubbles don't affect the capability of the solar panels though.
I cut off the end of a cell phone charger and soldered the wires to the solar panels. Then I took the circuit board out of the inside of the cell phone charger so that the 14 volts would go straight to the contactors on the cig plug.
Then as long as you have done the Cig Outlet Always On Mod then these solar panels will send voltage to the trucks battery through the cig outlet wiring.
It actually works, I think. When I plugged it into the cig outlet the voltage on my trucks battery went from 12.57 to 12.59 within a few seconds. These don't put out much current, but if you left your vehicle parked outside at an airport or something for a week then it would probably add up and make a difference in the state of your battery. It should be able to more than make up for the power that your trucks security system is sucking from the battery.
I've got to do some testing to see if this thing was a waste of time or not. I'll leave it on my dash board while my truck is parked at work, and I'll test the battery before and after I use the solar panel charger.
It easily lights up this 194 LED bulb.
I glued some vinyl on the back to make it look nice and keep from scratching up my dash. It folds in half like a big wallet.
