I’ve been following water inside my car and I cannot find the cause. The pictures are behind both the driver and passenger seat. Can someone please help? Thank you
Thank you for your input. I sat in the car and sprayed it with a hose and didn’t see any water come in through the doors seals. Also, the headliner is completely dry. I also took off the rear bumper to see if the plugs were missing and they were there. The front driver side was wet as well. I guess the next steps are to remove trim.Hmm. Is it happening when it rains but the vehicle is not moving, i.e. sitting parked? Is the headliner above those areas damp? I would start by drying it out really good. Then put some dry paper/paper towels/tissue down on top of those spots. Then soak the top of the vehicle with a hose and to see if it is dripping down from above. If it gets wet still by pouring water on the top but the paper isn't wet, I'd look to see if there is a break in the weatherstripping that is allowing water to channel down the sides and under those trim pieces into the carpet.
Dumb question. Will this apply if I do not have a sunroof?if the headline is not wet, its probably not the sunroof drains.
BUT, toyota runs the sunroof drains into the frame rail and then out the bottom.
look where you put the jack under the car and look at the pinch welds. youll notice small gaps every so often. those are the drains. if they clog, the water backs up and onto the carpet where your right toes would be (sitting passenger side) and left toes (drivers side).
this is what i did and it works like a charm.
All this is soaked as well. Under the back seats.Did some digging. Both sides were full with water, about 3 inches. Where would this come from?
