hey, need some help with axles, replacing the passenger side on a 90 prizm. i got a 5-speed. so is there anything i should know? i need to replace both sides, but the drivers side isn';t as bad popping right now so i was going to wait.
ok, questions, do i need to drain my transmission fluid before i get the axles out? on either side? i just changed transmission fluid, so if i do i want to try to catch it all and just put it back in there, with my extra, or maybe buy 1 quart more.
ok so where im as so far. everythings off on passenger side, but the axle wont coem out. i can borrow the tool at the store, an axle puller. so since im borrowing that tool, how about the drivers side axle? i heard it was hard too. does the axle puller, aslo install? is there anything extra i need to do, to pull off the drivers side axle? the passenger side it was just, remove axle nut, tie rod upper bolt, then the 3 bolts, nuts holding the lower control arm to the ball joint, the sliding it over, tire off, and theres the axle hanging. axle nut, tire, upper side tie rod nut, 3 bolts nuts holding lower control arm to ball joint. then getting the axle out. took a piece of wood and wedged behind it and pushed it with foot, until the wood broke, the axle wont come out.
so any difference in the drivers side? not much difference in work? should if i want to save my gear oil, go ahead and drain it out now? or hell just go get some coastal oil or somethign? is it goign to leak? and do i just need some extra, and top if off after im done?
thanks for any help and i need some help kinda quick, cars outside, and i need to get it done so i can get out.
