1 - 6 of 6 Posts
Hey folks,
Just wanted to show off and somewhat show the DIY steps on how to install an RS3200 vip alarm system on an Echo. Recently, I was lucky enough to find a junkyard echo with an ultra rare, RS3200 system installed with it. I painstakingly pulled it off the car and transferred it to my Echo RS HB.
Here's what you need to know.
Discussion Starter #2 (Edited)
First off you're going to need a key like this!
286204
I don't know if this is 100% true, but if you have the one exactly like this one but without the led at top, it will not work. That kind of key is only compatible with oem alarm systems.
Programming the key:
This is what you're going to need.
286198
The wires sticking up are for the security indicator light and GBS(glass breakage sensor) mic. The indicator which can also be seen on the top right, could not be removed from its clips, thus I had to cut it.
The wires that I am holding is the antenna. It is usually grey on most rs3200s but this one was green with a red stripe.
286194
286195
286196
286197
Passenger side.
286199
Driver side.
286200
286201
Piezo buzzer spliced with the harness.
286202
Piezo buzzer installed in the engine compartment. Wires go through the wiring firewall.
286203
I know this is a crappy write-up and it doesn't show all the steps, but If you guys have any questions, I'll try my best to answer them!
So is this what you got when you optioned remote power locks at the dealer?
My RS has a "normal" Viper without any Toyota branding on it (don't know where in its life that was installed)
This would have been an option that you could have had back in the day. It would be in the range of a $1000. I had the system pulled off of a junk yard echo, so this did not originally come with the car. Also powerlocks came standard on echo hatchbacks. Viper alarms and aftermarket immobilizers were common dealer ports as well, so chances are, the viper was dealer installed.
Sweet write up a much needed, will be doing this eventually if I can find a rs3200 system...
I'm still confused about the echo I saw on craigslist that had the factory alarm system with manual locks
1 - 6 of 6 Posts
