1 - 9 of 9 Posts
· TN's furry friend
1995 Toyota Camry LE
how many inches is your sub? there is a ratio of sub diameter to air ratio for the box to use
edit: you can always get polyfill box stuffing and put some in your sub box. the point of the stuffing is that the stuffing changes the air volume density in a box, so the driver performs as if the box were bigger. use 1-1.5 lbs. of stuffing per cubic foot of volume.
*i seriously think cotton or polyester stuffing will do the same thing here :D and be cheaper*
8" - .35 internal volume (cubic ft)
10" - .65 - 1.25 internal volume
12" - .85 - 1.75 internal volume
15" - 1.5 - 2.25 internal volume
· Grenaded piston
Polyfil and polyester stuffing is the same stuff.
Polyfil = polyester fiber stuffing.
You can get a big bag of it from Wal-Mart for a few bucks.
· Resident slacker
2015 Highlander
Yeah, it all depends on the drivers you're running. Just try not to obstruct the hole on the back of the magnet where the voice coil is.
3 of my old CompVR 10s were mounted at a 45-degree angle to the bottom of my enclosure with about a half an inch from the bottom at the lowest point, and I didn't have any problems with that setup.
1 - 9 of 9 Posts
