1 - 2 of 2 Posts
RAV4
I've installed a set of Spacers on my 1997 Toyota RAV4. These spacers are 1.25 stainless steel. But I look at the front tire, it has a negative chamber. But I take it to the aligment shop, and they say it's fine. The machine says that it has the OEM aligment. They also check the front suspension and everything is OK. Can anyone advice me what to do?
watch for abnormal tire wear or take it to a different shop for a different opinion......if you get abnormal tire wear, spacifically camber or caster, you know there is a problem, but normal wear will cause some of that also, a good tire rotation habit can cure that in many cases
1 - 2 of 2 Posts
