Spark plug sockets
2841 Views 7 Replies 6 Participants Last post by  Joebklyn
Quick question, for the Toyota Corolla 1zz-fe (1.8l, 2004), what socket set or sizes do I need to remove the spark plugs?
You guys could even recommend sets if you wish
1 - 8 of 8 Posts
I have this set and it is so beneficial to use since it's magnetic:
Reactions: 1
I believe its a 14mm. I usually just loosen with deep socket 14 and grab it with a magnetic pickup tool
Reactions: 1
Thank you 😁
years ago when changing spark plugs, i kept a long plug boot which works great for pulling out plugs and when putting the new plugs back in because you can use the boot to screw them in mostly and then switch to a socket. swing by a mechanic shop and ask if they have any deepwell boots from a plug change in the garbage and just ask for one. they are quite handy
Reactions: 1
YEAH MAN!!!!!!
Truper 13365 / D-5320-50 - 5/8" 6-Point Spark Plug Socket, 1/2" Drive
I second the Gearwrench all 1 piece 14mm ext with socket. Got real tired of trying to fish a detached socket out of the hole.
1 - 8 of 8 Posts
