1 - 2 of 2 Posts
I know what you all are saying, who uses a torque to tighten spark plug. Well I need to know because I am replacing a sleeve that was inserted on one of my plugs before I bought truck. So now after all this is done I can have a fresh plug again. Oh, old sleeve was frozen to the old plug. I'm using a cylinder head rethreader kit made by KD tools Part number 2125. I chased the threads with a tap and they cleaned up really well. I took a vacuum cleaner and adapted a step down to a flex hose to quarter inch diameter and made a pre filter in the hose, then vacuumed out any loose shavings out of cylinder. i caught most shavings on the oiled tap. I have 1993 t-100 v6 194
1998 T100 SR5 2WD
According to the FSM, 13 ft lbs fer spark plug to cylinder head torque specs. Try it at that and double check the value after 50 miles.
1 - 2 of 2 Posts
