1 - 13 of 13 Posts
2013 Subaru BRZ
While replacing me valve cover gasket, I broke one of the spark plug wire holders. These are the small plastic holders that are fixed on the engine to hold the wire in place. You can see them in the attached picture. It is one of those small holders in No. 3 that can hold 4 wires. I am wondering if I order this wire set:
http://www.amazon.com/NGK-TE58-Wire-Set/dp/B000C5PZP8
Whether a new one will come with the replacement holders. These things are very brittle after 15 years. So be extra careful when working with them.
Various Toyotas
I'm pretty sure they don't come with the NGK wires. You might be able to get that from the Toyota dealer for cheap. You don't have to pay shipping when the dealer orders a part for you. It comes in a couple of days later and you pick it up. I'm sure there are generic ones, but the Toyota ones fit into a hole in the valve cover, for an exact fit.
I snapped the plastic base off the one on my I4, so I replaced the base with a piece of angle aluminum and a small bolt. If the upper part that clips onto the wire breaks you have to get a new one.
It gets almost as brittle as the EGR valve/tube!
Various Toyotas
The Toyota spark plug wire set, comes with two of the clamps. Here's a photo:
http://www.ebay.com/itm/GENUINE-TOYOTA-SPARK-PLUG-WIRE-SET-OEM-90919-22400-/231834991987?hash=item35fa713d73:g:U3QAAOSwPhdU6UT1&vxp=mtr
You can also buy the clamps individually. For my son's '99
J-VIN Camry there are four clamps:
90464-00556 Holds three wires (comes with set from Toyota)
90464-00740 Bi-level: holds two wires at the top and two wires at the bottom (comes with the Toyota set).
90469-05006 This piece has a stud, which fits into the valve cover
90469-05008 This piece has a stud, which fits into the valve cover
Various Toyotas
Zip ties are all you need..
Ha, yes.....zip ties are a GREAT innovation.
Also duct tape, super glue, aluminum foil, and.......the spray on hair that a balding person can comb into his/her remaining hair:
The BABES are back!! :lol:
2013 Subaru BRZ
Discussion Starter #11
thanks! this is impressive. will order them.
2013 Subaru BRZ
Discussion Starter #12
Thanks for the help John. Finally remembered to get it from local dealer. 05008 is the longer one that holds four wires. 05006 is similar to 05008 but holds 3 wires. The simple holder is about $5, kind of steep. But the feeling of getting everything in order is priceless :whatwhat:
1 - 13 of 13 Posts
