What kind of plugs are you running (vendor name and #)?
Bear
Bear
The above reference to incorrect plug is why I asked. @ 330,000 I suspect that you are burning some oil. Correct plug is NGK BKR6EP11 or Denso PK20R11. I prefer NGK because of their low resistance.it is too lean or too hot, youd have black buildup if it was rich.
Common causes for this are:
- Incorrect spark plug (too hot heat range).
- Low octane fuel.
- Timing is not set properly.
- Cooling problems, (dirty cylinder fins, no or low water if water cooled, low or no engine oil).
- Carburetor air/fuel mixture is too lean (too much air).
- Leaking crankshaft seals, no oil, base or head gasket
He isnt removing them because they are a problem. He is jsut cleaning them off and what not. I see no problem with that.You should NOT be removing your plugs every time you change the oil. If you are having to doing this, something is wrong!
Buy you some new plugs ( correct ones are about $7.00 each) and leave them alone. This is alot cheaper that messing up your cyl head threads by removing your plugs every time you change your oil.
Bear
Well the main PROBLEM is that you are dealing with an alloy head. According to the Toyota Factory Manual, the plugs are to be replaced every 60,000 miles. Why would anyone want to take out the plugs every 3000 miles? Please post back when a plug pops out of the hole.He isnt removing them because they are a problem. He is jsut cleaning them off and what not. I see no problem with that.
The BKR6E11 is a traditional plug and not recommended by Toyota. The BKR6EP11 is a Double Platinum plug( good for 60,000 miles) listed as the correct one in the factory manual.My plugs will not 'pop out of the hole'. I know how to tighten them down properly...and WHEN to tighten them down. This has been done for all of the 333,xxx miles on this car and still no problem.
Thank you for your concern, though.
P.S. Just checked the plugs...they are NGK BKR6E11....not the BKR6EP11. So...wrong plugs put in by step brother? And..would this affect gas mileage at all?
