Spark plugs
1116 Views 10 Replies 8 Participants Last post by  amerikim
I just recently got a 91 camry le with a V6 and I'm having problems getting to the back spark plugs. They're under the entire intake manifold! Does anyone know the easiest way to get those babies out 'cause they need to be replaced.
1 - 11 of 11 Posts
The repair manual probably says to remove the upper intake manifold... You might be able to get in there with some wobble extensions and the patience of a saint...
-Charlie
Why do they make it so hard to get to those things? It's like they want to try your patience or something
You can do it, just have to sacrifice some skin and have the luck of seven drunk irishmen. Or maybe one scotsman.
That's how I did it....took a long time and it's a pain in the a$$, but I did it without removing anything...
A extension and a universal joint should do it for you.
They don't intentionally try to make it hard. It's just the way the engine/engine bay were designed.
*And lossing some skin is part of the job:D
I did it without taking the intake manifold off. It took me 2 1/2 hours, but it was better than paying the Toyota dealership to do it.
I used extensions and universals to reach them. You can do it!:)
yup, I did it too, lots of people have. Use the search button to do some research, it helps before you start.
I just did it a few weeks ago. Not as big a deal as most woudl haev you believe.
lots of extensions and 3 universals gets the job done did all six in 45 minutes. my new v6 solara took me 1 hour
I used one articulated joint, one 3" & one 5" extension. All Sears.
and two band aids when done.
1 - 11 of 11 Posts
