1 - 8 of 8 Posts
Avalon
After quite a search I found a coupon code for www.sparkplugs.com
They seems to have real competitive prices and I have had no problems with them of yet.
Use "dodgetalk" to get 10% off.
They carry Denso and NGK plugs which work well in Toyotas.
They also have 02 sensors and wire sets.
98 Camry XLE V6
nice find, but on spark plug wires...do we just need 1 qty or 2? Every part of each wiresets construction meets or exceed OE/OES specifications. 3 Wires per set
because it said ^ 3 wires per set...i need 6 for a v6.
i would have assumed that wire set means for everything...please clarify if you can.
TN Pussy Man
Camry
you actually only need 3, since the 1mz is half distributorless and has coil packs
only the other 3 have wires and a dizzy
therefore, you only need one set of 3 wires
That Acura Guy
^ distributor
For sparkplugs when i enter quantity do i put in 2 or 4? I know in reg. stores spark plugs come in sets of 2s.
98 Camry XLE V6
TTercel said:
^ distributor
thanks thats what i thought he meant. so 1 set will be fine for me.
my denso plugs i bought at autozone came in boxes of 12 but they are individually packaged. i'm going to assume you need 4 qty.
Avalon
Discussion Starter · #8 ·
They sell them individually so you enter the actual qty. For example
I4=4
V6=6
V8=8
*when they come they are in packs for example I got a 4 pack and 2 singles for my V6
In response to the above post I bought the NGK wires and they are nearly the same as OEM. My 1MZ-Fe had Yazaki wires and they seemed to be fine (didn't resistance test them), but I just wanted to do a 100K mile tuneup. I got the Iridum (NGK) plugs and I like them. Plugs looked fine too, but if you neglect to remove you may not get out when they do go bad, so I just spent the $75 and did everything. Plugs in the back are kinda a hassle as I had to lay on the engine.
1 - 8 of 8 Posts
