1 - 6 of 6 Posts
2017 Toyota Corolla s
I have a 2017 Toyota Corolla and the speakers like to cut in and out. Why does it do this? What can I do to stop this?
2014 VW Passat Tsi SEL
Do you have any remaining warranty?
Administrator
2006 Corolla XRS
Yes. And the extended one as well.
I'd look closer at the connector. There has been some owners of this gen that found corrosion in the connector that interfered with the electrical connection.
This would apply to car washes, rain and snow. The barrier is supposed to restrict the moisture within the door frame. But it does happen to get corroded.
Spray dielectric cleaner in the contacts and see if that helps. If not, then you'd need to get some .110" quick connects and cut off the factory connector.
1 - 6 of 6 Posts
