1 - 7 of 7 Posts
Hi, I have a 2009 Sequoia with the Air Suspension. I need new front and rear shocks which I never changed before. Would I need special shocks for the car, or can I use the normal shocks for any Sequoia? I was searching on amazon.com and seeing shocks with the comment "W/O Auto Levelling", so I guess will not work?? Can anyone advise, or provide part numbers which they have used on their similar cars?
My VIN is 5TDZY68A69S021509
thanks,
Oneel
Super Moderator
2005 Corolla CE
You need shocks for air suspension models. They are significantly stiffer than the regular shocks. Using the wrong shocks will result in the truck bottoming out constantly.
Hi , would you know the correct part number or model for the shocks for the air suspension? I am not sure if the shocks are normal or special for the air suspension
fronts are 48510-34010 lists for $244.81 each
rear 48080-34020 and 48090-34010 they list for $791.63 each
these are OEM only, no aftermarket is available. there are a number of online suppliers that sell OEM parts at discounted prices
https://parts.conicellitoyotaofconshohocken.com/
https://www.sparksparts.com/
If it was mine, I would get rid of that air suspension stuff and put regular coil overs on it. 800 bucks for one shock is insane.
Super Moderator
2005 Corolla CE
Those prices are standard retail. Online wholesale prices are below:
Fronts Part #48510-34010 are around $162
https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-shock-absorber-4851034010
Rears Part #48530-34051 are around $425
https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-shock-absorber-4853034051
Add around $30 - 40 for shipping.
Since you have air suspension, you have to use OEM stuff. I would shop the dealers or shops in your area for better installed prices. I am guessing you can get labor down to around $400.
Discussion Starter #7
Thanks all for the feedback! I think I have to go with the original parts. Very pricey though!!
thanks
Oneel
1 - 7 of 7 Posts
