I have 92 Camry (3VZ-FE 168000km).
Problem:
When I drive around 20-80Km/Hour, the needle wanders 20-40Km/hour. The needle of speed meter never point to the accuracy data. If I drive around 100KM/Hour, The needle point to Zero and stays over there. Now, My crouise not work at all.
I doubt a couple of issues. The First One is speed sensor. The Second one is cable issue. the third one is the speed meter issue.
I can not buy those three parts, then try one by one to find out the problem. I Can remove the Speed sensor from trans.
Question One,
Does any one can tell me, how to test the speed sensor is good or not?
Question Two,
If I fix the issue, the cruise will come back to work automatically?
Thank You Gus.
Jason
Problem:
Question One,
Question Two,
Thank You Gus.
Jason
