I took my 07 TRD Sport DC LB with 29k miles to my local dealership to get the TSB done. I have a 2.5 spacer lift in the front and the rear is stock. My ride gets harsh when i load one of my miller welding generators in the bed. I was hoping not to have any problems but they denied the TSB because i had a after market lift in the front which voided my warranty. :headbang: they said they might do the TSB if i removed the spacer and then they would perform a test to see if the springs need to be replaced
i called toyota to see if i could reverse the verdict because there is a TSB for that specific problem but they said that because its lifted, the weight of the truck has shifted and that might be the problem.
has anybody gotten the TSB done with a lifted front end? or should tacoma owners have this done first before they start to mod their trucks.
what should i do?. should i remove the spacer and take it back or just install an AAL myself and not let the dealership touch my tacoma again.
any help is appreciated :sosad:
