1 - 5 of 5 Posts
need your help guys... i just changed all belts last week... timing, alternator, AC etc... this morning when i get into the car and start to drive it is fine... when i went to make a turn the car just starts squeaking its head off... sounds like its coming from the belts... possible power steering??? anyone has a clue??? i know this is common cause it happened on my mom's corolla but was sold before had to fix it...
You may need to add power steering fluid or maybe the belt is too tight/loose, try spraying some wd-40 on the belt....
96 3MZ M/T
Camry
check the tention on the power steering belt it may be a little loose. also make sure you have enough fluid.
You should check the tension and power steering fluid level as mentioned above but i would not recommend using wd-40 because it can cause the belt to slip and wd-40 glazes the outside causing the inside to wear faster and unless you take a close look the belt will appear fine but it's actually worn, use a belt dressing they're at any automotive retail store for like 2 dollars
Country Hick
2001 Nissan Pulsar
Is it a solid squeak or a pulse? If its a pulsing squeak, its the PS belt... If it is a constant, it is the alternator/AC belt.
1 - 5 of 5 Posts
