At first I just thought it was the clutch pedal spring. Eventually I got some WD40 and sprayed every part of the clutch pedal assembly that I could get at from inside the car right up to where it goes through the fire wall.
No dice. The noise is just getting worse. I looked in the engine bay and the clutch fluid resevoir just goes into the fire wall. I couldn't see any thing to spray in there.
It's gettting pretty anoying. Anyone know what it could be?
How to I get at the clutch master cylinder?
Thanks
From looking at the haynes manual, it apears I have to remove the lines/de-presurize the system to access the pushrod. is this true? Or can I just pull the boot back to lube it up?
