97avalonxls said:
what is the double throw relay for, multiple applications?
In some applications you need a spdt relay.
One example would be a starter disable relay. Where under normal conditions you want it connected.
But, when the alarm is armed and you try to turn the ignition, nothing happens.
What the relay is doing is disabling the starter when the alarm is armed and receives a trigger from the ignition switch.
A relay is nothing more then a electromechanical switch.
For what your doing, you can use either or (spst or spdt). If you use a spdt relay, you just won't use 87a.
also will your post make alittle more sense once I acquire the relay, cos I'm a little confused.
One you have the relay you'll see what I'm talking about.
It'll either have 4 terminals (spst) or 5 terminals (spdt). The terminals are labeled with a number (87, 87a, 85, 86, 30).
also can i take the 12+ off the amps distro block
Thats fine.
