1 - 10 of 10 Posts
Hello ,
I recently bought a Camry 2002 SE V6 (Yes I love it!).
My previous car was a Camry 98 4 cyl. Teh 4 cyl woudl start almost instatly upon cranking. Teh V6 however, seems to require more "time" before motor starts.
Is this something that woudl be comparatively normal?
The V6 requires aboout 1.5 to 2 seconds to get started while the 4 usually kicked in right away.
Any experience here woudl be appreciated.
thanks!
98 Camry XLE V6
lgmab said:
Hello ,
thanks!
Well it all depends. For me, cold starts take 2 seconds while warm starts typically just start right up.
i wouldnt worry about it unless you feel its cranking way too many times before it is able to start or if it has some real trouble starting. If you notice a time increase over time you may want to get it checked out. Otherwise you're all good.
VeeZed
1988 Toyota Camry V6
Yeah at cold start, mine typically takes a few seconds...it's nothing to worry about. When hot, it fires up pretty much straight away. Even if it took a little longer, unless it took AGES for it to get going (like...5-10secs) or fires and stalls etc, then theres nothing to worry about.
lgmab said:
Hello ,
thanks!
my 99 v6 takes a few seconds longer to crank when the engine is cold and the weather is cold
my 93 i4, 250k miles, start right up as soon as i step on clutch and turn the key, even if the engine is cold and outside temperature is below freezing, my i4 battery looks smaller than the v6 too.
3s-gte in a Camry?!?
'89 Camry Alltrac
Turn the key to the "on" position for a couple seconds before going to the "start" position. This get the fuel pressure up. Check it out - it should help.
-Charlie
VeeZed
Do the newer Camry's work like that now?
As far as the old AFM ones go, that wont work, as the FP is triggered by the AFM signal on Start.
'89 Camry Alltrac
Correcto. Only the 'newer' cars will work this way... IE, any built after '91. :lol:
-Charlie
1 - 10 of 10 Posts
