I posted a while back with an intermitant starting problem. got some usefull advise and tried everthing everyone suggested with no luck. finally tracked the problem to the wire that plugs into the starter was not getting power. there was a break in the line where some one had previously spliced into that line and the connection went bad. was making intermitant contact hence the intermintant starting prob. after the wireing harness was relocated for the airbag suspension that was being instaled it totaly lost contact. but with the help of Adam Berg from Settintrendz.com (the guy doing the air ride set up on my yota) he tracked the bad connection down and now the truck starts like a champ! so for those intermintant starting probs check that line for any possible bad splices or connections. pics of the the air ride set up can be found at that web site above Adam dose Killer fabrication, bodywork, paintwork and custom stereos.
