You're welcome. My mentor was Popular Mechanics, Hot Rod, Car and Driver, and Rod and Custom. Later, it was Big Bike and Chopper magazines.
If you have a long crank time, try this. Turn the key to ON a couple of times, then go for the start. If it catches right away after that little procedure, you are having a delay in starting while fuel pressure builds up, and you may not be holding line pressure. Most in-tank units have a check valve built in to keep fuel from bleeding out of the pressurized line and draining back into the tank. Sometimes, the fuel pressure regulator keeps pressure from building to full spec. Give it a try.
Oh, and the "replace parts until it's fixed" method is costly and frustrating. You wouldn't believe how many beginning techs use that method.
"Test, don't guess."
