1 - 4 of 4 Posts
What is the steering fluid type for 2005 scion xb? and, what is the fluid capacity for the steering system? does any one know?
thanks
1995 T100 2WD
thanks
The 2006 holds 500ml (16.9 ounces) but I doubt you'll be able to drain it completely.
So 1 quart should do the trick..I would use the Red Line Synethic Power Steering Fluid!
compatibility issue
I cannot remember well, but it was a while ago that i read somewhere about compatibility issue between some versions of Dexron ATFs. Any one here knows about it?
1 - 4 of 4 Posts
