It looks like I am going to have to replace the steering rack and pinion unit on the 1992 "Whac-A-Mole" Camry. I can see a drip coming from the boot bellows and was able to locate a small tear in that second fold - that I tried to patch but no luck. I don't think replacing just the boot would be a long term fix anyway because the seal on that end must be tired.
I have already tried using a fluid seal conditioner (that seemed to help for 18 months) and just recently replaced the fluid again. This time it isn't helping, unless it's related to the cold temps, so it may be time to correct the underlying problem.
The plan is to keep the fluid topped off and hold off a month or two for warmer weather; but since this is going to be a pretty big job I want to get it right the first time.
I may go with a familiar reman. brand like ACDelco or A-1 Cardon, but I see RockAuto has several other brands that I've never heard of too. If anyone has experience with these steering racks, I would appreciate your brand recommendations.
Also, I checked the outer tie rod ends and they seem fine. Nevertheless, is this the time to purchase and install new tie rod ends (while the rack is out), since mine are original with 247k miles? Or, should I not try and get too far ahead of the "Whac-A-Mole" for now? :starwars:
