I have a 1990 Gt hatchback, and i just got a deck for it last night, but the damn car is soo confusing that I cant even get the stock deck out of it, i cant figure it out??? A little help plz???
Remove the piece around the shifter. [pull up from the little whatever tray in the center console, then pry up on the rear]
Remove the piece around the radio. [should have 2 screws on the bottom, under the shifter trim, then GENTLY pry the top out with a flat tip screwdriver]
You will be able to see the 4 screws that hold the rad in from there.
I might also recommend getting an intallation kit specific for your installation. It takes all the confusion and frustration out of the wiring and makes for a quick, professional looking install.
I've always used Crutchfield but I've heard that Best Buy and other electronic stores also sell them.
1 - 3 of 3 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
