Short story: 7GME with BHG just got replaced along with a valve job. I got the car back and noticed the throttle sticking quite a bit while driving. This became very apparent when I parked it and the throttle was stuck open at 4k rpms. Mechanic that did the work says that the throttle return spring is bad. The problem is that we don't know the original weight of the spring and Toyota doesn't make an OEM spring.
Also, I cleaned the throttle body with carb cleaner when I got the car about 15k miles ago. He said that he also cleaned it when he removed it to do replace the head gasket.
Does anyone know what weight spring would work for this engine? Any other ideas on what would cause the throttle to stick open? Should I just buy a universal kit and try them all?
