I just did my timing belt, Changed the Crank Shaft Seal, Cam shaft seal. I didn't think/know to change my Oil Pump seals. So I'm going to get back in there and change them hoping that this will solve my Oil leak problem.
Should I go on and change the entire Oil Pump while I'm back in there or just do the seals?
If I just do the seals, do I have to remove the entire Oil Pan?
I can't believe I have to do this all over again..
Thanks
-Ben
Thanks
-Ben
