1 - 11 of 11 Posts
All parts are cash local pickup only, I'm in california in the 626/909 (Pickup locations will be pm'd to buyer)
Check out the car parts I have for sale: http://www.toyotanation.com/forum/showthread.php?t=296149
Here are the parts...
2 12" Polk Audio DB12-4 Subwoofers in a Q-Logic Sealed .85 Enclosure. ($75 Each)
Freq. Response: 20-200Hz
Sensitivity: 86db
Independance: 4 Ohm
Max Power (RMS): 400W
Max Power (Peak): 800W
Streetwires 1 Farad Capacitor with Mounting Brackets ($20)
MTX Blue Thunder Pro50x4 ($75)
25 Watts RMS x4 into 4 Ohms
50 Watts RMS x4 into 2 Ohms
100 Watts RMS x 2 into 2 Ohms
250 Watts Bridged into 4 Ohms
Not sure if you know, MTX ratings are conservative.
MTX Blue Thunder Pro150x2 ($75)
75 Watts RMS x 2 into 4 Ohms
150 Watts RMS x 2 into 2 Ohms
425 Watts Bridged into 4 Ohms
Alpine CDA-9833 AM/FM/CD/MP3/WMA($50)
motorized, detachable, fold-down face
variable button color
plays MP3 and WMA files
plays audio CDs, CD-Rs and CD-RWs
MaxTune SQ tuner
12 FM/6 AM presets
Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
MediaXpander (restores clarity and detail to compressed or broadcast audio)
source tone memory
iPersonalize setup options
XM and SIRIUS Satellite Radio controls
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
4-volt front, rear and subwoofer preamp outputs
V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery
clock
wireless remote
26 watts RMS/60 peak x 4 channels (CEA-2006 Compliant)
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
Kenwood KGC-9044 Graphic Equalizer ($50) SOLD!
detachable face
11-band equalizer, 12 dB boost or cut for each band
11-band multicolor spectrum analyzer display with white LED backlight
3 sets of gold-plated 4 volt preamp outputs: front, rear, and non-fading
6 factory-preset EQ curves
3 user-programmable EQ curves
display contrast and dimmer adjustment
low-pass electronic crossover (50/80/120 Hz)
high-pass electronic crossover (40/60/80/120/150/180/220 Hz)
signal-to-noise ratio 88 dB
THD 0.01%
2003 Toyota Matrix XR Factory Stereo AM/FM/CD/Cassette ($40)
Thanks for looking!
Discussion Starter #7
I removed it because I forgot where I put it when I moved. I can look for it again, PM if your interested, thanks.
1 - 11 of 11 Posts
