Does anyone know the stock head thickness for an 88 4age? Can't find it in my Chilton manual. I read on a website it is 4.568" from factory. I am asking because my head has been surfaced twice. The first time was 10 years ago and I don't know how much they machined off (it has a shim about .030" between the block and head gasket). It was just resurfaced again in my current rebuild another .004". I just measured the thickness as 4.555" (.013" below factory). If that is correct, do I even need a shim at .013"? If I don't add back that .013" thickness with a thicker head gasket, will it affect the timing? Use a MLS head gasket instead of a shim? Thanks in advance. Oh and I don't know the difference between cam timing and ignition timing....if either will be affected.
