I know its been posted before but where can I find how to remove the stock stereo on on 04 tundra?
links help...
Thanks
It is simple. This is what I had to do on my 01 Tundra, but it should be the same or very similar on an 04.
Gently pull off the 3 HVAC knobs. There is a screw behind each one. Remove the screws.
Then, on the two air vents on either side of the radio, push them inwards at the top. Again, you will see a screw in there. Remove the screws.
Now, the whole HVAC/Stereo console assembly should slide right out. It may need some gentle "encouragement."
Remove the four bolts holding in the head unit; two on either side. I think they are 10mm.
You're there. :clap:
