1 - 20 of 35 Posts
· A Poor College Student
1994 Camry Sedan LE
I'm pretty sure he means body roll..... like when you turn a container with a liquid in it sideways and the liquid (car) stays level while the container (you) is twisted.....
· Auto-Cross Addict
Flashmn said:
strutbar wont really do anything to bodyroll if the suspension is soft. But yeah, what is fishbowl effect anyhow?:confused: :hammer:
Lies!!!!
I just got mine. Man does it help! Normally you would feel the car set into one side when turning hard.... It no longer does that. It holds strong and has less tilt. It helps majory with body roll.
It helps a lot. Even on stock Suspension. An obvious difference. It's worth the $100 you pay for one.
When you buy a strut bar, make sure it is a legit one. There are a bunch out there that are just cheap GM productions. They don't work for shit.
· nice guy
all strut bars will not effect a stock suspension, i would go with everything..and go with tein....or cusco
my car is corolla AE 92 4-door sedan, which DID NOT have an front swaybar or even a rear sway bar. I first found a rear swaybar and it makes the tail less sluggish in cornering.
I waited for two months for the front swaybar, and as expected, it makes a big difference.
Then I mounted a front strut bar. It makes a difference that I can feel for sure. I don't think it reduces body roll in cornering. In cornering, however, I do feel a clearer response from the steering wheel.
The body flex slightly affects the alignment settings in cornering, though temporarily. And this may gives you a brief fuzzy feeling in cornering. The strut bar helps reduce the body flex in the front part of the car, and it thus reduces these changes in alignment setting.
· ooSnip3r Halo2!
89 Corolla GTS
Ahhh the fishbowl effect I get it..funny.
Dont put a strut bar on your stock suspension...it'll wear your top caps out prematurly.
stiffer springs..and stiff side walled tires!
Of course thats just my opinion.
· Resident asshole
Corolla
Most sedans I've seen have the rear sway bar. But having no front swaybar isnt that bad really, thats the classical way to get your FWD to oversteer is, to put a really stiff one in the back and remove the front one.
^ True, and if you have a front bar too you want the rear one to be bigger/stiffer so the car will handle more neutral.
· Auto-Cross Addict
Flashmn said:
I have a strutbar, didnt make much difference, really. I think its just a mental issue that it helps :rolleyes:
McPherson Struts?
Nah, no mental.
Normally when you take an off ramp, you feel the car set into the outside. With the strut bar, it no longer sets in. It holds strong and keeps both sides more firmly on the ground.
Keep in mind, we have different cars. And maybe you got stuck with one of the cheap GM ones. Those don't do shit.
But I have been testing mine out for the last week straight. Off-ramps I could previously only take at 65mph, I was now taking at 80mph. It helps a great deal. Trust me, I have one too :)
Hope you just tried to amuse :D
why we need to oversteer?
Lack of a front swaybar makes cornering, cruising, or even lane changing uncomfortable to me. It should never be a good thing to make a car less controllable on the road, should it?
It's embarrassing to get proud of my efforts to get the front swaybar restored while it is taken for granted (or even unnoticed) in almost any other cars.
· Resident asshole
Corolla
Umm... it shouldnt make it uncomfortable, its just basic principles of car handling and suspension tuning. Yes, I've studied that too, I got a big text book about it.
You can observe how the front swaybar helps stabilize the car body by reducing the vertical movement of the two sides of the front part of a car. The name "stabilizer" should be enough to explain this. Its effect may be minimal when you drive on a really flat road. However, perfect roads are rarely found.
By "not comfortable" I just meant "not stable"
1 - 20 of 35 Posts
