1 - 11 of 11 Posts
TN's furry friend
1995 Toyota Camry LE
you will need the following tools:
22mm socket
21 mm socket
19 mm socket
13 mm socket (i think that's the size for the rear sway bar endlinks)
12 mm socket
14 mm socket (again, what i think the top nuts for the front strut mounts are)
^Basically, a standard socket set.
1/2 inch drive ratchet
36" breaker bar (you can go shorter i suppose but this make it way easier)
jack and stands
spring compressor (loan-a-tool from auto parts dealer, simple and easy to use)
If you do it yourself, make sure that you squeeze the spring down with the compressor completely. I thought that I had enough turns on the compressor tool and when I released the spring the spring openned up a lot. It took me close to an hour to squeeze the spring down completely alternating between a chain and the compressor tool.
Kep
'95 Camry V6 XLE
What places loan spring compressors? I went to an AutoZone and Kragen but I didn't see any there.
I just called my local AutoZone yesterday and they said they have them. I assume they're behind the counter since it's a loan out item. The guy said you pay them $50, keep them as long as you want, then get your money back when you return them.
Gen 3
Expanding on Whiterabbit's reply
Front stuts
22mm socket (2 bottom bolts)
14 mm socket (top 3 bolts)
19mm (Top Strut retaining bolt, if they are stock)
12 mm socket (brake line bolt)
Rear struts
21 mm socket (2 bottom bolts)
12mm for Rear sway bar brackets, just in case you decide to upgrade the swaybar at the same time.
14mm (Rear sway bracket nut)
#5 Metric allen wrench - Away bar bracket.
If you change to tokicos the top retaining nut they come with is a 22mm retaining nut, stocks are 19 flare retaining nut.
1 - 11 of 11 Posts
