Your description leads me to believe the problem is not your muffler. Bosal makes excellent mufflers and I would not replace it with a bolt on. Welded joints will last longer, are stronger, and seal better. I think your car uses a dual muffler set-up. Usually when a muffler starts to go, the sound will become gradually louder with time. It never hurts to have the car diagnosed by a mechanic. It may be something in the drivetrain or brake system. But, I would need more info. Here are a few quick and easy things you can do:
1) Check your CV boots for tears.
2) Worn wheel bearings also make noise, but usually noise is more constant. You can jack up one wheel at a time and turn the wheel listening for noise and feeling resistance.
3) Check belt tension.
4) Check all fluid levels.
