Just bought Lucas oil to add in transmisison. Can't find transmission oil outlet. How do i add this to transmission.
I'd say the same applies to the older A43DE in the MX73s, when I had slippage a fluid flush made the transmission seem brand new.if its just a little rough on shifting i've found that the A340E in the mx83 cressidas responds very well to a fluid flush.
My 88 Cressida had the EXACT same problem. The transmission just wouldn't shift into second gear when the engine was cold. I had to drive it slowly for about half a mile before it would shift, or just let it warm up for a very long time. I ended up flushing the transmission a couple times with regular Valvoline Dexron III fluid (if you just pull the plug and drain it, you will only drain about a fifth of the fluid, thats why I drained it, ran it for a bit, drained it again, etc.).Thanks for replying. i'm adding lucas oil because my car wont shift to second gear when cold. I have to wait 10 mins. Just read in previous blogs that adding lucas to transmission fixes the problem. If this doesn't help, i'll get the transmission flushed.
